Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Alert suppression
jmdi
I'm montoring more than 500 cisco nodes,I've define one alert if node goes down but also an alert for each interface on node.
How do I suppress alert on interfaces when a node goes down ?
I don't want to configure 500 dedicated alerts ?
Thanks for you help
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Hi Dierick,
I'm not sure I understand your question, but here goes.
Basically you have created an Alert for any of the 500 Nodes go down, and another alert for any of the interfaces on those nodes being down?
Someone please correct me if I'm wrong, but if a node goes down, you do not receive interface down alerts for that node as well?
In this case you do not need to configure alert suppression, unless there are other nodes which you are monitoring, behind the node which just went down. Also have a look at this post on setting up alert suppression correctly:
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
Josh_Stephens
Dierick,
You can setup your alerts to do what you describe without configuring alert suppression. Just be sure that when you build the alert for the interfaces that you alert only when they are in a "down" state. If the node is down the interfaces will enter an "unknown" state and should not trigger your alert.
HTH,
Josh
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
