Hi Guys,
Do you know if its possible to create a report tha will list new nodes added within a set date range?
I have looked but cant find the area?
Hey Craig, you can see new nodes added in the Event Manager.
Just select the time range & you will see all nodes added, deleted or changed, depending on the type of event selected.
Ah yes... Thank you.. I totaly forgot about that..
Thanks for the pointer.
do you know if its possible to get this emailed weekly?
I have some event type reports already built, and will post them to the CSZ when I can.
