The new SolarWinds LANsurveyor product automatically discovers your network, provides an interactive diagram of your entire network, continuously scans the network for new devices, alerts you when new devices connect to your network, and provides hardware and software inventory data.
The following short PDF provides step by step instructions for importing LANsurveyor network diagrams into Orion.
http://www.solarwinds.net/resources/democenter/Orion/LANsurveyorMaps.pdf
More tutorials are availabel at http://www.solarwinds.net/support/tutorials.aspx.
Haley,
We have LANsurveyor as part of the VISIO 2003 resource kit. Can this be used to create the Orion Maps?
Phillip
Yes but it is static and will not update any changes-
The full LANsurveyor solution will notify you anytime a new device connects to the network and automatically add new devices to the network map, then you can export the updated map into the Orion Map Maker.
