Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Toolset Intergration
dannori
Hello,
I am setting up a new intall of Orion and things are going very well. One thing I am having an issue with is the toolset intergration. In the manual it states that the first time I access the Orion web page I will be prompted with a security warning about intalling SWToolset.exe. Well, that never happens yet I have a new install of version 8 on my desktop. Any ideas?
Dan Bradley
WAN Engineer
Lifespan Corporation
Find more posts tagged with
Accepted answers
All comments
mgibson
Once You have Orion up and going, When you access Orion from the PC that has the Toolkit installed you will get the prompt.
dannori
mgibson,
I have Orion up and running with 100 hosts in it. I can sign on to the web page from my PC and have all fuctionality except the toolset piece. Do I need to have a tool set installed on the server also, in addition to my desktop?
mgibson
No, From the PC that has The toolkit installed, access the Orion Web site, when you do, it will prompt you. There is a preface to this! You must have the Allow Browser Integration checked in your account profile on the Orion Server /admin/account views/Your account for this to work.
dannori
Allow toolset intergration is checked but i still get nothing. I even tried setting up a new account but to no avail.
mgibson
I am not sure what the required versions are, but you will not only need the version of Orion that supports Toolset integration, but you also have to have a version of the Toolset that supports this. You should contact Tech Support and they can quickly go over what you have vs what you need. And troublshoot any problems you may have.
pblatz
The toolset integration is an ActiveX extension. You can manage how IE sees the add-on from Tools/Internet Options/Programs. Click Manage Add-ons. You should see a list of programs IE has used / activly in use; find swtoolset.engine disable it. Restart IE, browse to Orion. you should be prompted to integrate the toolset.
P. B.
Success requires three bones--wishbone, backbone and funnybone.
Kobi Yamada
BryanBecker
There is an IIS URL Scan tool that can potentially block things from running. In out case, because we secure these servers down, URL Scan was blocking all .exe files from being run. And in order to get the right-click working you have to let swtoolset.exe run from the site.
You will see something like this in \windows\system32\inetsrv\urlscan\logs
Client at X.X.X.X: URL contains extension '.exe', which is disallowed. Request will be rejected. Site Instance='1', Raw URL='/SWToolset.exe'
That is something you will need to allow.
BB
dannori
Thanks to everyone for your help. It was URLScan that was killing me. I had our WEB security guy allow .exe files and all is well.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
