Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Getting rid of map from the web view
skaczkowski
Hi again
Is there a way to completely remove the Network Map area from the web view? I'm trying to streamline the whole interface and have decided that the Network Map is pretty much useless for our needs.
I've been able to delete the default USA map, but now I just get an error message stating that it can't load the map and would much rather just not see this area..
Thanks again!
Find more posts tagged with
Accepted answers
All comments
skaczkowski
Ahhhhhhhhh..
Figured it out, seems that I had to dig a bit in the customize view area....
Network_Guru
Hi Steve,
You can make any page your default home page, and add or remove any page view from the menu. Just make sure you have checked the advanced features box on the Web Admin page.
You can then remove the map view from your home page.
This also allows you to create different menus for various users with views limited to only certain network devices based on any number of node properties.
Check the on-line dox & tutorials as well, they are very helpful:
www2.solarwinds.net/.../default.htm
www2.solarwinds.net/.../Tutorials.htm
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
