Hi
I generated the report .
I need that report on daily basis so that i can schedule in a way that automatically generate get the report through the mails
Rohith Murthy
Have you tried Orion Report scheduler on your primary poller (for older versions of NPM)? In latest version NPM 10.7 it has been embedded onto your Web Portal (Settings -> Manage Reports -> Schedule Manager)
Hi Vinay
Thanks for the reply ,
I checked and found only NCM can schedule from the web console not the NPM or SAM
FYI i have attached the screenshot please find
Legacy reports have to be scheduled from the Primary Engine. There are a couple of feature request out there for people to vote on to have a converter to convert legacy reports to be web compatible.
