All three are in the Nodes Table and the CustomPropertiesMetaData Table, but one of them no longer appears in the Custom Properties editor nor the Node Editor. Any thoughts? I have an open Ticket, but have not heard anything from TS yet.
We worked with Support. They were unable to fix the missing Attribute. We ended up creating a new one and moving the data via sql manager.
That is odd. I have upgraded 3 different customers and have not seen this behavior. Please let us know what support comes back with. I would suggest that if you don't hear back soon to call the support line and get them on the phone.
Somehow, one of the Custom Attributes became viewed by the NPM as a builtin attribute. All we could do is add a similar attribute and thenn use a SQL command to copy the data to the new column.
Resistance is futile.......your custom properties will be assimilated.
I've never seen (and hope I never do) that one...I have dozens of custom properties and that would seriously break things.
What are the names of the 3 custom properties and which is the one that didn't come through after the upgrade?
DeviceType
WanTechnology
EntityType -- this is the one that became a standard property during the upgrade
