Hi
I Am trying to set up orion version 7.8.5 for the first time.
Without wanting to appear lazy, I've read through many posts on here and I still wanted to confirm that I understand what the polling and statistics settings actually relate to, and how they affect the graphs.
So... the 'polling' tab controls how often orion checks that the device is still up, and collects packet loss info etc, which it stores in the sql database and uses to plot the graphs, I take it that the more often you poll a device the more likely you'll spot issues OR does it, just take stats produced internally by the switch/router. In other words what does increasing/decreasing the polling frequency actually do ?
Same question for the Statistics tab, I take it that it collects stats as a snapshot of what the interface had at that moment or is it just collecting stats from the router which the router itself has complied? I read in a previous post that cisco devices produce internal stats every 5 mins so setting the 'statistics collection' to less than 5 mins is pointless. In other words whats does increasing/decreasing the statistical collection frequency actually do in terms of graphs. How does this differ to running a bandwidth guage from the Engineers toolset and collecting stats every 3 secs. ?
One other question was about the Detail + and Detail - buttons, these seems to affect the bandwidth utilisation quite dramatically on some graphs, e.g, the default detail shows 6Mbps throughput over a short period, and then increasing detail ramps it up to 8Mbps.. Probably a simple answer, is this just showing a peak to 8Mbps at some point, a point which was averaged out in the graph with less detail ?
Apologies for the newbie questions, any advice most welcome.
Regards
Dan
