I've just recently starting working with NPM again after a couple years without touching it so bear with me. One item I've been looking at is what will happen if I edit the All Nodes resource under a view. Specifically, if I change how the nodes are listed, will it only be for that view or will any view using the All Nodes resource also be changed? If it will change for all views using that resource, is there a way to make a custom sort of All Nodes resource that could be used just for this view? I was able to make a table, but that didn't look as nice and also was fully expanded and took up a lot of space.
