I am interested in publishing a network map to our support intranet or publishing our node list to show availability. Is this possible?
Depending on what you are using for your support intranet and it's capabilities I can think of two options
1) Use URL Direct Link to embed a view as a portlet in your support portal
2) We also have a SDK available to pull data out of Orion and you can then work with that
If you want the SDK, let me know as you need to request it.
can I get the sdk?
Using joomla for portal
You can get from here
