I changed the names for our Brocade switches and even after a forced redisocvery this update did not propogate down. I would think it would.
Since I had recently added the node I deleted the node made sure the node was gone in the DB then added it back. I didn't feel like writing the SQL query to change that portion of the FullName.
Is this a bug or this is expected behavior?
James
