We are trying to run a batch file by using the trigger action "execute an external program". When we run the batch file manually everything is good. However, when we cause the alert to trigger to test it out, nothing happens. We think this may be due to a "pop up run dialog box" that happens once you double-click the batch file when running it manually. Obviously, Advanced Alert Manager has no idea what to do with that dialog box when it tries to execute the batch file. I'm sure there has to be some way around this, I'm just not sure how. Any help would be greatly appreciated.
