Hi to all, i want to know if when a disk of a server is in a high percentege of utilization ,example 95% , the status of a server change to warning state instead of continue being normal?
Thanks in advance .
Diego
Out of the box, the global volume usage threshold is set to 80% for warning and 95% for critical. Warning makes it yellow and critical makes it red.
You can set this by clicking on Settings then Orion Thresholds on the right.
Sohail Bhamani
Loop1 Systems
http://www.loop1systems.com
Sohail, that only affects the volume reporting, that will not change the server not to critical...will it?
A node's interfaces and volumes are automatically children of that node. It should trickle up from the voume to its associated node.
Now i have some disk at 100% to check if the node change his state , but nothing happened. I dont know if i have to create a monitor application to do it.
