I use Huawei device, and it's login command to enter high user level is "super", not "enable" as in cisco.
for example:
telnet x.x.x.x
username:test
password:test
>super
test
#display current-configuration
omit.....
I have create a device template file,but due to can't auto login to "super"mode(as cisco enable 15), the function of "download config" can't work.
My Question:
Where can custom login command? Can I custom "enable" command?
I want to change the "enble" to "super" command .
I use the NCM V5.
thanks in advanced.
