Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Services Stopped
cjfsoares
I'm going insane with this!!!
I have NPM V8 installed in a W2k3 server SP2, and after i discovered all of my network the NPM as been running fine for some days.
After the first reboot all the services except NPM service failed to start with a timeout error.
Why did it happened and how can i fix it please.
Thank you.
Find more posts tagged with
Accepted answers
All comments
dperdue
There is discussion in the following thread starting on 1/25/07 that may help you:
www4.solarwinds.net/.../topic.asp
David Perdue
SolarWinds Development Team
BryanBecker
This was posted by amata and this was what I had to do as well after talking to support :
I have problems with the advanced alerts for a long time, but solarwinds finally give me the solution. I don`t know if it`s going to work for other people but maybe help someone.
For starters please make sure that .Net Framework 2.0 is installed on this machine. If so, please make sure that DNS and WINS are both configured properly on this server. If this is good, please disable NetBIOS over TCP if it is not needed. Then disable the WinHTTP Proxy Service. It will be set for manual start, but just disable it as this is the best route to resolve this issue. If it still will not start after making these changes, please add the following entries to your Hosts file:
127.0.0.1 wpad
127.0.0.1 CRL.THAWTE.COM
The Hosts file is located in System32/drivers/Etc.
My problem was with the advanced alert service engine, the service stops working after a while and never works again, until I made the entry in the host file.
This may help.
BB
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
