I suspect that this problem is due to the Cisco 1250 AP not having MIB support in Orion, however when you select an AP and look at the active wireless clients any client that is associated at 802.11N speeds, i.e. M15, will show as having a 7.5Mbps data rate. Since the 1250's have been out for some time now, is there any idea on when we will be getting proper MIB support for them, or if that is not the issue what can be done to correct this?
