I understand the concept of "Reserved" in IPAM, but I would also like to be able to designate certain IP ranges for certain intended uses.
For example, if I add a subnet without adding the IP addresses at the same time, I can then add ranges of addresses under that subnet. I would like to be able designate a range for a certain use, e.g. for routers or switches or printers. Se what I mean?
In other words, how can I designate certain IP ranges as set aside for defined uses without designating them as Reserved in the IPAM sense of the word?
