Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
moving objects in maps
Vieregg
In version 6.x one was able to move objects on maps by using the cursor keys. Did anyone find out how this can be done in version 7? It seems to be not there anymore. I have tried to hold down the alt or shift key while pressing the cursor keys but the objects just don't move.
Dirk
Find more posts tagged with
Accepted answers
All comments
DonYonce
When using the Version 7.x Map Maker...
First select the objects you would like to move, then use the arrow keys while holding down the Control key to move the objects one pixel at a time. Holding down Control-Shift will move the objects 10 pixels at a time.
Also, there are layout and alignment tools that can be added to the menu bars. Right click on any toolbar and select "Alignment" to display the Alignment tools.
Don
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
