Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Hardware advise
michael4702
I have just purchased the full unlimited version of Orion.
What hardware do you recommend for it.
I know its a "how long is a piece of string" question but my main concern is backing up the SQL database!?!?
How do other people back up there databases?
Many thanks.
Mike,
Find more posts tagged with
Accepted answers
All comments
michael4702
Anyone?
gbrance
I use a Dell PE2850 with 4GB of RAM and 2.8Ghz CPU and it works fine for 5,000 Elements. However I have the SQL backend sitting on our SQL Cluster. The database is backed up using Veritax Backup Exec 9.0 along with all of our other SQL databases.
Questions
1-How many elements do you intend to monitor?
2-Do you intend to have the SQL Server on the Same Server?
GB
jonchill
We use a Dell 2850 with 2gb of RAM and a Dual 3ghz Xeon. This is just for the Orion frontend and admin the database sits on it's own box similar to above we are monitoring around 3500 elements.
What I will say is that since we moved the database from the same box to a different box Orion seems to be responding a lot quicker.
HTH
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Seraphym
hey mike,
we are using
2x intel xeon @ 3,2 ghz
4 gb ram
monitoring 1200 nodes + 9000 interfaces. running smooth...
backup via IBM TSM scheduling every day at 05:00. we copy the full harddrive.
regards,
sera
mihi est propositum in taberna mori
FormerMember
With well over 4000 elements monitored and having been up for well over a year our DB is currently about 11GB. We use a IBM X346 with dual 2.8Ghz Xeons and 2.5GB of memory.
The SQL server is on a seperate IBM X346 that is a shared resource running on a similar chassis with 4GB of memory. Neither box has ever shown any sign of resource issues, but the Orion DB is definitely the largest running on the SQL server.
We backup the DB every night and copy the data to a secondary server that is backed up to tape. We do not do any transactional backups though.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
