Hi All,
The monitoring for the data sync across the databases of Always on SQL 2016 cluster is not available. For the below test server (X.X.X.X)and the database,
Can you please confirm is the monitoring setup for SQL 2016 production servers only or is there any setup done for test servers as well.
How to Monitor below as well:
| Errors from the error Log |
| Operating system error |
| backup log with truncate_only or with no_log |
| setting database option recovery to simple |
| the metadata is inconsistent |
| cannot be opened due to inaccessible files or insufficient memory or disk space |
| backup sets on the media might be damaged and unusable |
| A nonrecoverable i/o error occurred on file |
| Database out of Sync |
| Database XXX is marked Restoring |
| The log is out of space |
| An inconsistency was detected during an internal operation |
| Severity: 19 |
| Severity: 20 |
| Severity: 21 |
