Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
v3.5.1
FormerMember
Installing this Version
To install this version of Cirrus Configuration Manager, you do not need to uninstall your previous version. Shutdown any running Cirrus applications, and then run the setup program. The setup program will detect and uninstall your previous version without a loss of customizations.
This didn't seem to work for me...has anyone else tried the upgrade?
Find more posts tagged with
Accepted answers
All comments
support
Could you provide more details on what you are seeing? Any specific error messages?
SolarWinds Support
FormerMember
I could be missing something but it says just to run the setup file. I have done this and noticed no change in the product version. Does this upgrade change the prodcut ver. under the help tab? Should I be doing Modify, Repiar??? It acts like I'm almost installing the same version.
FormerMember
I've tried twice now. I get the option of "modifying, repairing or removing" the program. I don't see anything I can add to modify it and when it finishes, it looks exactly the same as before. Oh, it still says 3.5 for a version AND it still has the same problem I had before that they have suggested I upgrade to fix.
-Steve
FormerMember
shewww, I thought it was just me. Can I recommend that when a new version comes out the setup file name follows the version number.
Example V3.5 = SolarWinds-Cirrus-V3.5DL500
Example V3.5.1 = SolarWinds-Cirrus-V3.5.1DL500
support
Is this occuring from version 3.0 to 3.5.1?
or from 3.5 to 3.5.1?
SolarWinds Support
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
