Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SNMP Keep Alives
gbrance
Last week the Data Engineering team was having trouble with SNMP and one of there Cisco switches so they asked me to stop polling it. I selected unmanage and stopped managing the device. However every 15mins the Orion Server was still sending SNMP requests to the device. Does Orion still do some basic SNMP pulling even after a device has been unmanaged? The only way to get it to stop was to delete the entire Node.
THanks-GB
Find more posts tagged with
Accepted answers
All comments
dperdue
We have looked into this issue. Orion continues to do "Rediscovery" while a node is unmanged. This will result in some SNMP traffic.
A work-around would be to change the node that you want to stop polling to a static IP within Orion (Select Node in System Manager, then select Nodes->Node Details). From here you can change the IP to another IP (bogus, loopback, whatever). This will stop Orion from sending any SNMP traffic to the node. When you are ready to remanage the node, change it back to dynamic or the correct IP.
David Perdue
SolarWinds Development Team
FormerMember
Thanks for feedback and the workaround David.
A "Disable/Enable All Polling" (like "UnManage/Manage") button would be good to have so the work-around is unnecessary. I, myself, would prefer to see checkboxes implemented rather than buttons.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
