Hi All,
Receiving the below error when changing the sorted field to Custom Property fields under Manage Nodes. Noticed that if i sorted by a custom property that existed for ALL Nodes then would NOT receive the error.
However when sorting via a custom property that only existed for some nodes i got this error.
Found a way around by entering data into the custom property fields, removing this and then the Manage Nodes would display Unknow(XX).
Anyone else had this issue or found an easier fix then entering data and removing it??
Regards
Michael
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.ServiceModel.CommunicationObjectFaultedException: The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it is in the Faulted state.Server stack trace: at System.ServiceModel.Channels.CommunicationObject.ThrowIfDisposedOrNotOpen() at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at SolarWinds.NPM.Common.INPMBusinessLayer.GetValuesAndCountsForNodeProperty(String property, String accountId) at SolarWinds.NPM.Common.NPMBusinessLayerProxy.GetValuesAndCountsForNodeProperty(String property, String accountId) at Orion_Nodes_Controls_NodeGrouping.Reload() at Orion_Nodes_Controls_NodeGrouping.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
