Is there a way that I can tell how many licenses I have and how many are in use in Patch Manager
Here you go.
You can also select your patch manager groups to see how many nodes are in that group. Tells you at the top.
Also manager computers, just select workstations from the dropdown.
Thanks James, that's exactly what I needed.
You are more than welcome.
