Hello Please help me how to set the backup of Checkpoint edge utm appliance and 1100 checkpoint device
help me with script
Hello.
There are 2 templates out on Thwack that might work for you. You can find them inside Orion or here:
1) Checkpoint_FW_Template-1.3.6.1.4.1.2620.1.6.123.1.48.ConfigMgmt-Commands
2) Check Point GAIA 77.30-1.3.6.1.4.1.2620.1.6.123.1.48.ConfigMgmt-Commands
Best regards,
Steffen
Just to piggy back on what Steffen posted......if those thwack checkpoint templates don't work, you can modify the templates once you import them. You might need to slightly modify some of the show running/startup type commands to match the cli syntax of your specific checkpoint model.
Regards,
Parker Robinson
Loop1
