I have spend many days trying to get my Cisco routers (12.4) working with the Network Traffic Anaysis and nothing seems to be working (no firewalls are blocking).
Can someone provide a cisco config that actually works with this tool? Ideally, I want to capture sub-interfaces and also our WAN interface (multilink and/or serial interfaces).
interface Multilink1
ip flow egress
ip flow-export source Multilink 1
ip flow-export version 9 (have tried ver 5 as well)
ip flow-export destination x.x.x.x 2055
In the network analsysis site
NetFlow Receiver Service [server] is receiving a NetFlow data stream from an unmanaged interface on 172.x.x.x. The NetFlow data stream will be discarded. Please use the Orion System Manager to add Interface #14 in order to process this NetFlow data stream.
What does it mean by Interface #14? We only have 4 interfaces on the router. All interfaces are setup in Orion.
