Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Server Migration Woes
RSimmons
Hello,
I am trying to migrate from our Test server to the new production server. I have been following the steps in the SolarWinds migration guide, however once I restore the database from the old server - run the Configuration Wizard, then I get an error when starting the System Manager. A screenshot of the error is attached.
The database version is the same, the user names and passwords used are the same. I have tried backing up and restoring from both the Orion Database Manager and from the MS SQL Interface with no luck. The system seems to refuse to use an existing database completely, as if I simply get the Configuration Wizard to create a database (even with the same name) then it starts no problem (just without all of our data).
Any help would be appreciated, as we urgently need to move away from our test server but cannot afford to loose the data.
Dakaix.
Find more posts tagged with
sql_database_migration_error
Accepted answers
All comments
mark_wiggans
Verify that
Orion has admin credentials to make the
initial connection to the new SQL server-
RSimmons
Hello,
I was able to correct this by getting the Configuration Wizard to create a new user account on the same database.
Thanks though.
-Dakaix
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
