Is it possible in 8.5 to put all nodes into unmanaged from a certain time to a certain time? I see how to do each individual one.
This is not possible in 8.5, but it's something we plan to add.
Hi Denny
Under a particular node, sometime a WAN connection via Serial or Ethernet or even and edge switch may be offline for maintenance planned or otherwise.
Are SW considering the option to put a particular interface from a node on maintenance mode? A router can have multiple ISP's in any one router and the maintenance times are of course going to be different.
Ken
I believe what you're asking for is the ability to unmanage interfaces. I've requested this very feature in the Orion feature requests located here...
It's definitely on the list.
