Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SQL errors on Orion
vsreddy
Does anyone know why I would need to rerun the Config wizard and restart web services from time to time to resolve the web site from disconnecting from the SQL database??? this is becoming an issue I hope has an answer.
Find more posts tagged with
Accepted answers
All comments
pfoged
I hope this helps,
I had lots of problems with the SQL functions. I eventually moved the SQL portion to another server and upgraded the license to a full version. I also ensure that there is at least 6gig of free space at all times.
Orion can hog alot of disk space and it can also hog alot of your sql user licenses.
Peter Foged
Network Specialist
Network_Guru
I run both Poller & SQL database on the same server. The most important thing is having enough memory if you are going to do both on the same server. I have 4 gigs of RAM and the Enterprise SQL database uses 1.7GB. The database is ~ 2.7GB.
When all is said and done, there is around 1.5GB RAM free, so you
could probably get by with "only" 3GB.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
