Is it possible to stop Orion from generating the default events such as Node Up / Down, Node Changed, etc.?
Peter
Go to the alerts menu in Orion System manager, select alerts or advanced alerts and you should see the options to allow you to suppress or activate an alert type.
Thanks for the reply, if I understand you correctly; that will allow you to configure some alerts but not the built-in alerts such as changes to a node, etc.
I do not think you can disable them, nevertheless you can filter them out. See the following thread.
Here are the Orion NPM Event Type you could filter with the method describe in the above thread.
Each Orion module adds its own list of Events to this one.
1 Node Down2 Node Warning5 Node Up8 Node Removed9 Node Added10 Interface Down11 Interface Up12 Interface Shutdown13 Interface Unknown14 Node Rebooted15 Critical System Error16 Interface Added17 Interface Removed18 Interface Remapped19 Interface Changed20 Monitoring Started21 Monitoring Stopped22 Interface Enabled23 Interface Disappeared24 Interface Reappeared25 Fail Over26 Fail Back30 Application Stopped31 Application Restart40 UnManage Node41 Manage Node100 Node Changed200 Volume Remapped201 Volume Changed202 Volume Added203 Volume Removed210 Volume Disappeared211 Volume Reappeared
