Is there any way to get Cirrus to backup the Vlan Database on a Cisco Switch in VTP server mode? This info is found using the show vlan command, but isn't in the running config of the switch.
I would create a job to copy vlan.dat from the VTP servers.
This post describes how to backup a route table. This can be used to backup a VTP vlan.dat info by using show vlan instead of the standard show run.
