I have a situation in which my Orion database has more than 1000 routers/switches in it. I am using Cirrus v4 and would like to import from Orion into Cirrus. I noticed that the Import wizard apparently will only let me import the IP Address and the Community string. The other columns that display from the Orion database have the word <ignore> over them and cannot be selected for import.
Is there any way to import the custom properties that I have spent so much time configuring in Orion, so that they maintain the same association in Cirrus, or am I forced to construct custom properties all over again in Cirrus?
Or, could I possibly import the custom properties by using another import source otherthan the Orion database?
Any ideas?
