Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
"Edit selected Node" not working
hez
Did a clean install of v3.5, but have an annoying problem. When right clicking a node, the "Edit selected Node" function doesn't work, nothing happens. But strangely enough if I use "Edit multiple nodes" it works ok. Anybody else seen this? And have a fix?
Find more posts tagged with
Accepted answers
All comments
direland69
Yes, I'm having the same issue. Edit Node does not work, but Edit Multiple Nodes does. Problem is, I need to change the IP address on one of my nodes and can't.
Mithrilhall
You could change the IP address via the database until SolarWinds fixes the bug (I have not confirmed the bug - I do not run Cirrus).
direland69
That worked. Thanks!
hez
Another temp fix, Created a "dummy" node, so that I can do a multiple edit. Changing the password for example is'nt so easy in the DB, as they are encrypted..
mkocsis
I'm glad I read these things. I'm having the same issue. I'm going to try the 'dummy node' scenario.
Michael Kocsis
Data Communications
City of Tampa
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
