We have active license to use KIWI CATTOOLS but it is for Version 3.4,
Is it possible to update KIWICATTOL to its latest version by carrying the same License that we are using for version 3.4.
Please reply
Hi nks7892,
It depends on your maintenance status.
If you have active maintenance for CatTools, you can download the latest version from your customer portal.
If you don't have a valid maintenance contract for CatTools, you will have to pay for upgrade.
Technically, you will use a new activation key for the latest version in either case as the licensing technology has changed since v3.4.
Regards,
Jiri
thanks Jiri Cvachovec
