Hi All,
Is there a way on LEM wherein I can configure the appliance to monitor simultaneous logins on our system? I plan to create a rule that whenever LEM received a logon events, it will automatically create a login file or sheet where the login accounts will be registered and then delete the accounts whenever LEM received a logoff events. LEM will then send an alert whenever it receives another login events for a certain account/s that are still on the login file/sheet. When I checked on LEM rule actions, the option that I think I can use is append to a text file. But I cant seem to find a way to make a rule that will remove the account on the text file. I can't also seem to find the option to have a rule that will match the account involve to a file. I'm not sure if this is the correct approach but if anyone can recommend a similar thing that would be nice.
Any help would be very much appreciated.
Neil
