Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Config Backup Stopped working after upgrade to 3.5
jedi755
Anyone else having this issue? We cannot perform mass backups, it seems to lockup and never finish the job.
Find more posts tagged with
Accepted answers
All comments
jonchill
I noticed this today some backups work and some don't but it's not the same switches every night it seems random.
I've logged a call with support to see what they say, I'll let you know when I hear anything.
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
danrog
I noticed after the upgrade, the Global protocol variable names changed. I had to update all my hosts to the new vairable names before I could get automated/manual config backups to work. Hope this helps.
BryanBecker
This may be your issue. I have a nightly device failure report sent to me an usually it's pretty small. After the upgrade I had alot of failures.
After the upgrade the new communication option "Request Configs Using" was added. I think it's default is telnet. And after the upgrade all the devices where updated with this new option and it was left blank...therefore defaulting to telnet. Since my devices only use SSH I had to edit multiple devices and change that to SSH auto.
Once I did this it worked.
HTH
BB
jedi755
I had the same issue with the "global default protocol", I fixed it and still getting the problem. One thing I noticed is that it is only happening to my nodes where the groups are larger than 1000 nodes. Still working on a solution.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
