Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
OID polling
FormerMember
I think it will be very beneficial for the customer if the MIB Viewer on Solarwinds allowed users to write a script that would automate the polling of OID values off network elements.
This will be better than manually putting a network element, community string followed by the specific OID and then extracting the values.
Is there anyone who has maybe found a way of integrating another tool with Solarwinds ?
Find more posts tagged with
Accepted answers
All comments
FormerMember
I'm not sure if I'm on target with what you're asking for but if you add the OID to the SNMP real-time graph tool, it will continuously monitor the OID. Orion v8 is a bit less flexible but will also poll a custom MIB. The advantage with Orion v8 is that it will do it as a service.
davemac
Something that may help you here is the MIB-Viewer-Scripts download from Solarwinds customer area (if you have maintenance). They provide some VBS sample scripts that allow you to specify host, community string and oid which will then launch the MIB viewer and extract what you've specified.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
