An Application monitor coming back up and an Application monitor in either a Warning or Critical state are all assigned Event Type 504. I would like to split those out so that.
are you trying to build an APM report where you need to split these out or just needing a new 'feature request'?
the latter.
I am working on customizing the Event Display in Orion. I have scaled back the background colors and icons associated with events to four of each. Background colors are now either Green (Good), Yellow(Warning), Red (bad)or Blue ( events associated with Orion administation and maintenance like nodes added, deleted, changed etc).
Because a monitored service coming back up has the same event type as Service Resource usage going above the established warning or critical thresholds they all show up as green and I want Resource Usage Warning to be Yellow and Resource Usage Critical to be red and only the Service Up to be Green.
i really like that idea...
maybe someone watching from Solarwinds will see this and pick this up as a FEATURE REQUEST.
Hi Larry--
I'll make sure the product manager sees this.
M
