Hello,
Curious how you maintain Java updates.
Do you publish, use the package boot manager to uninstall old versions and maintain 3 different Java applications?
Like right now I'm going through and publishing these:
Java Runtime Environment 8u152 (x86 for x64) (Upgrade)
Java Runtime Environment 8u152 (x64) (Upgrade)
Java Runtime Environment 8u152 (x86) (Upgrade)
So is that correct? Every time there is a java update you have to maintain 3 packages? Can Oracle get a clue?
