In solarwinds if we keep any device in unmange state (in maintenance state) will that reflect in the report?
We can prevent alarms when kept in Maintenance but wanted to know about the report ? will that show in the report
Hi
you may refer the below and create report which will give you the required information.
Table layout
Regards
Mohit
Thanks a lot Mohit....Its Really helpful
You are Welcome... Cheers
