Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SolarWinds Lab Equipment
Josh_Stephens
We're currently working to expand our labs and need your input. We would like to hear from you with regards to the types of equipment that you're using in your network, especially if that equipment is hard to manage using SolarWinds software.
Thanks in advance for the information.
Josh Stephens
SolarWinds R&D
Find more posts tagged with
Accepted answers
All comments
ggroen
Netapp equipment and then especially the volumes, snapshots and the virtual ethernet ports.
lavelanet
Equal logics SANs, APC UPS equipment, PowerWare UPS equipment, HP switches, Sun Solaris machines, HP HPUX machines, IBM AIX machines, Dell Servers, SuperMicro Servers
Would especially like to see more data from the EqualLogics SANs.
BryanBecker
As I said in the Cirrus thread.....NetScaler load balancers & Cisco VPN appliances like the 3030s.
BB
aLTeReGo
EMC CLARiiON SAN and Brocade fiber switches are very difficult to manage using SolarWinds. SolarWinds usage has expanded in our organization and Storage is the next place people are looking for detailed reports on just like they are receiving for the Ethernet network
Built in support for APC and Liebert UPS & Cooling Equipment would be AWSOME!
Just my $0.02
mpearson
Alvarion Breeze Series Fixed and WiMAX wireless base stations and subscriber units
DragonWave, Motorola, Ceragon fixed wireless solutions (all are ip/snmp managed)
pguenther
Nortel BPS 2000, Baystack 450 (switches that require Ctrl+Y to log on. Cirrus cannot do this currently). Alteon Application switch (menu driven interface). Nortel Contivity (tunnel support is lacking currently)
rowle1jt
HP Servers
HP/3Com switches
Liebert UPS's
Barracuda Spam Firewall
Watchguard Firewall/router
Systems Analyst --Imperial Company, Inc.
trm33
Netscreen sub-interfaces and VPN tunnels
Thanks Tim
Network_Guru
Just about any VPN concentrator could do with some custom reporting - number of concurrent connected users. Number of times users login in per day. How long each session lasts.
We use Cisco 3030 & 3080 VPN concentrators, but are looking at the new ASA5500s as well as Juniper Netscreens.
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
rjacobs
I'll second NG's comments. We are using ASA 5510's and the VPN reporting would be sweet.
I'll also second lavelanet's recommendation on the IBM AIX boxes.
conway
Nokia IPSO Firewalls
F5 BigIP load balancers
F5 SSL VPN
Brocade SAN switches
hez
ZyXel IES Dslam series 2000/3000/1248/5000
Alvarion Breeze VL SU + AU
UPS's MGE for example. (Should have a default MIB Polling scheme for UPS's)
/heZ
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
