I am seeing lots of issues with running config backup, sometimes they work sometimes they don't. When running them manually, I see the thread count start to go negative and then the activity hangs.
Is anyone else seeing this?
A quick update to this post, I un-installed CatTools, (after exporting devices and activities), installed CatTools, and the problem of negative threads has been resolved. Now I have an issue with the backups stopping at midnight, and having to be restarted.
Hi Bob,
If you haven't already done so, I'd recommend raising a support ticket for this one as it will most likely require an indepth investigation to work out what is going wrong.
Regards,
Steve
