quote:Originally posted by dlucas10I'm wondering if there is a way that I could add MIBs to Orion?? I have a device that has MIBs but Orion knows nothing about that device. Any help would be appreciated.Thanks
quote:Originally posted by josh@solarwinds.netWhat MIBs are you hoping to import into Orion? Specifically, we're looking for information on:1. Types of devices that you want to monitor2. Stats that you want to collect/monitor3. OIDs that you're trying to collect fromThanks,Josh StephensSolarWinds.Net
quote:Originally posted by josh@solarwinds.netVic,Our goal would be to make the application as flexible as possible. We're looking for the MIBs and statistcis that people want to use so that we can test our methodologies against these requirements.HTH,Josh StephensSolarWinds.Net
Has there been any more accomplished on this yet? I've got equipment I'd like to try using Orion to monitor but it doesn't have it's vendors MIBS built in. I can obtain them myself though. I'm trying out version 8.1 of Orion. I can not find any mention on the main Solarwinds web site yet about being able to do this.
But, custom MIB polling is not the same thing at all as being able to incorporate additional MIBS into Orion.
But speaking of custom MIB polling, has anyone been able to figure out if an Orion custom MIB poller can take the data from a simple byte counter and derive and graph a byte or bit rate from it?
Yes, we support polling of custom MIBs. I think you'll be more successful with Orion 8.5.1, which is the current version.
A couple of resources for getting going with this:
www.solarwinds.com/.../OrionCustomPollerSetup.html
www.solarwinds.com/.../wwhelp.htm
Denny, thanks for the quick response! Are you saying then that I CAN add a vendor supplied MIB into Orion 8.5.1? I would expect then that yes, I could setup a custom pollers to poll OID's from that vendor supplied MIB. Is this correct?
Additional resources-see attached pdf
links-
Our MIB database has tens of thousands of vendor MIBs, and the custom MIB poller will leverage that DB (which is not the same as what's built-in), but even if we don't have that MIB, all the Custom Poller needs is the OID. You do not need the MIB--just the OID.
I need the APC PowerNet MIB added to Orion please.
ftp://ftp.apc.com/apc/public/software/pnetmib/mib/403/powernet403.mib
You will need to open a Support Ticket, and we will add them to the Database, and the Support Technician will notify you when they are available.
Adding new MIBs to the SolarWinds MIB Database does not automatically add monitoring or additional functionality other than for Traps. Adding MIBs will help you if you are using Universal Device Pollers as indicated below.
Note: After submitting your MIBs to the SolarWinds MIB Database, you must download and install the new, updated MIB database to gain the benefits of your added MIBs.
If you do not immediately know the OID that you want to poll, you can use the Universal Device Poller application to browse the MIB tree to find the data you want to poll. If you already know the MIB and/or OID for the data you want to poll, you do not need to add the corresponding MIBs to the SolarWinds database. Of course, adding your MIBs may be of assistance to another SolarWinds user in the future.
The following resources provide more information about Universal Device Pollers:
Traps
If your Orion server receives a trap from a monitored device, and the relevant MIB for the trap does not exist in the installed SolarWinds MIB Database, Orion may not display the correct data. Providing the relevant MIBs for your devices will resolve this issue, once the updated MIB database is installed.
If you feel you have a MIB that hasn't yet been integrated into our Master MIB, try this first:
- Open the Univesal Device Poller program (Start -> All Programs -> SolarWinds Orion -> Network Performance Monitor -> Universal Device Poller)
- Select NEW UNIVERSAL DEVICE POLLER
- Select Browse MIB Tree
- Select Search MIBs
- Search by NAME (or OID) and then enter the Name or OID into the search field.
- in this case I searched for BdStatsEntry found in the BD.MIB, and it returned this MIB information:
1.3.6.1.4.1.289.2.1.1.51.2.2.1 (BD-MIB:bdStatsEntry)
This would mean the MIB is already integrated into the Orion Master MIB.
If you are not able to find the OID's you are looking for this way then please open a support ticket with NPM support and provide the MIB in your first reply email and let them know you were unable to find any OID's from this MIB. Support will help you get that integrated into our Master MIB.
Hello Josh,
They are load balancers. Just wanted to monitor them and get alert when they up and down.
D
