Is it possible to have the "Config Change Report" scheduled and set to be emailed?
I cant find anywhere to save the report and enable it in the scheduler.
Absolutely. Go to Schedule > Create New Job > Config Change Report. Under Notification tab, you can check the option to email you the results.
HTH,
Yep. that did the trick, i was trying to setup under 'Reports, Schedule Report".
Thanks for that.
No worries, anytime.
