Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Switch Port Mapper Problem
EricLeMonnier
We have a Cisco Catalyst 6509 with 2 gigabit blades and one 10/100 blade all on one VLAN. When I run the switch port mapper, it shows me only blade 5. I does not map out blade 6 and 9.
We I installed Orion, it can see all the blades without a problem.
Anyone have ideas how to get this to work?
Find more posts tagged with
Accepted answers
All comments
Bryan
Are you using the default VLAN 1 or have you made your own vlan? If you don't specify a vlan on the switch port mapper, it will only query for ports belonging to VLAN 1. If you are using say VLAN 20 as your default for all ports then when you enter the community string put an "
@20"
; on the end of it to query ports belonging to VLAN 20. I have two 5505's and the switch port mapper sees both my 10/100 and GIG blades. Not sure what else to tell you...
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
