hi, I´m new at this forum and also using the orion network traffic analyzer, i'm, testing it to force the company to use it
I introduced new fields on the node description like, owner, adress , etc..where do i fill that fields?
pampas
Pampas,
It sounds like you may need to have a look at the "Custom Property Editor". Information such as you mentioned above can be associated with nodes, interfaces, and/or volumes through the CPE, and can be displayed and filtered upon in a number of ways. As for how to input the data, those who have direct access to the Orion server itself can manipulate the data in these fields from within CPE. There is also the option of updating the info from the web site using the "Edit a Custom Property" resource.
