Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
RFE: TFTP Server - Run As Service
iunderwo
The TFTP server that SW produces is really the best one I've ever used on the Windows platform.
That said, I'd like to know how (or see it made as an option in the program) to make this program run as a Windows Service. I'd like to run this all the time on our server without having to log into it first and then run the application.
Ideas?
// Ian Underwood - Network Engineering
// Boston Stock Exchange
Find more posts tagged with
tftp
Accepted answers
All comments
jonchill
Here here I find it frustrating trying to run a script in Cirrus overnight that requires TFTP and remeber to start the TFTP server, it would be great if it could be upgraded to run as a service then I wouldn't have to worry.
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
chris.lapoint
We are currently considering the following enhancements to TFTP server in the next release planned for first half of 2007:
1) Blocksize option (RFC 2347, 2348)
2) Transfer size, and timeout options (RFC 2349)
3) Run as service
We'd love to get your feedback on relative priority of these features.
Chris LaPoint
Sr. Product Manager
SolarWinds
jonchill
My priority would be:-
Run as service
Timeout
Block size
Jon
Pilgrim Hospital
UK
FormerMember
Run as service would be very useful. We currently use the old Win NT support program which allows you to create a service and run TFTP server using that.
Its called srvany and the KB article is here:
support.microsoft.com/.../137890
Hope this helps in the meantime.
FormerMember
I've tried running as a service by using the Microsoft tools and instructions but when I do, it cant seem to find any files.
When I run directly and try to get a file, it transfers fine and the log reports
23/02/2007 11:02 :Sent sipDefault.cnf to (10.210.14.201), 3723 bytes
However, when I run as a service, the file download fails and the log reports
23/02/2007 11:22 :TFTP Error from 10.210.11.91 requesting sipDefault.cnf : File does not exist
Do I need to configure a run directory?
I tried to put a file to see where it would go but that also failed
Phil.
FormerMember
Panic over - just realised the problem is that I am using a network mapped drive
FormerMember
Hi All, I agree. I would like to see this run as a Windows service. In the mean time, I am using a script to call this prior to running an application that needs the server. I do this in order to guarentee that the server is running while my application is running. Can someone tell me how to close the server when my application is done ? Or, could you add a feature to disable or timeout the popup that says "TFTP Server Already open". That way, my script won't cause my operators to panic when they see this as an error message the second time they run the application. Thanks.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
