How do I create a chart that shows the Top 10 Interfaces by Percent Utilization?
IPAM 4.0, NCM 7.2.2, NPM 10.6.1, NTA 4.0.3, UDT 3.0.2, IVIM 1.9.0,
Thank you very much!!!! How do I make it into a pie chart or a bar graph? I am int he same configuration- just hunting for it.
Edited: I found it. TY
On the page where you want to add the resource select Customize Page > Click the + symbol next to the column you want to add the resource. In the Add Resource page do a search for Top XX Interfaces by Percent Utilization. Place a check box next to the resource and click Add Selected Resources.
Tony Vispetto I couldn't have put that any better.
