Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NetFlow Traffic Analyzer (NTA)
NTA 2.0 Service will not start
mikewat
I just installed NTA 2.0 And the netflow service will not start.
I get the two errors below.
Installing the performance counter strings for service SolarWinds failed.
Service cannot be started. System.ComponentModel.Win32Exception: The process cannot access the file because it is being used by another process
at System.Diagnostics.PerformanceCounterLib.RegisterFiles(String arg0, Boolean unregister)
at System.Diagnostics.PerformanceCounterLib.RegisterCategory(String categoryName, PerformanceCounterCategoryType categoryType, String categoryHelp, CounterCreationDataCollection creationData)
at System.Diagnostics.PerformanceCounterCategory.Create(String categoryName, String categoryHelp, PerformanceCounterCategoryType categoryType, CounterCreationDataCollection counterData)
at SolarWinds.Orion.Common.SWPerfMonCounters.CreateCounters()
at SolarWinds.Orion.NetFlow.AppContext.CreatePerformanceCounters()
at SolarWinds.Orion.NetFlow.AppContext.Initialize()
at SolarWinds.Orion.NetFlow.Service.NetFlowService.OnStart(String[] args)
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
For more information, see Help and Support Center at
Help
Find more posts tagged with
Accepted answers
All comments
FormerMember
Have you contacted Support? We'd like to help, but your error message doesn't indicate any known bug. There are too many unknowns to really diagnose on the Forum.
Denny LeCompte
Sr. Product Manager, Orion
SolarWinds
mikewat
Yes I have a case open
hvits
Did you ever a get a fix for this??
quote:
support
NetFlow 2.0 installs a number of additional counters in the Windows Performance Monitor. Support has found that on occasion this conflicts with certain Non-Solarwinds processes already running on the server.
In this case it was CSMon – part of Cisco’s TACACS server. Stopping this process allowed the Netflow service to start. If you are having a similar problem, try eliminating any non-essential services running on the server. If the service still won’t start, please submit a case to Solarwinds support.
SolarWinds Support
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
