When I install Orion NPM Hot standby engine I rcvd the following error, kindly help me out from this.
Hi there--
Go ahead and open a support ticket here. In order to receive technical support, you will need to be current on your SolarWinds maintenance. Complete the form. You will not be able to upload your Orion diagnostics, but you will receive an email back that allows you to upload diagnostics.
M
I was having the same problem..thank u for your suggestion.....I hope now it will work properly...:)
